Just got the tank fix.
Only averaging 350 miles per tank![]()
If you "just got the tank fix" how many fill-ups have you had since then to get your average of 350 miles per tank?Just got the tank fix.
"Miles per tank" is way too vague for discussion. Is this the dashboard estimate or from a trip meter? If the latter, at what level did you refill? What's your fuel economy? Is this the first tank after the fix?Just got the tank fix.
What MPG are you getting? Take a picture of just before each of the next two fuel fills showing the recent trip MPG, the position of the gauge needle, the odometer and your fuel receipt. Lets see what is happening.
Where do you live? What terrain? What speeds? How do you drive (agressive versus experienced hybrid)? What loads is the car carrying? Anything on the roof? Tire Pressures recorded at what temperature and after sitting or after driving? Snow/Rain?
10 gallons times 35 miles per gallon in winter isn't too crazy.
No way there must be Something wrong. I get a 340-360 range on a full tank with my gas modelJust got the tank fix.
Are you implying that you were averaging lots more than 350 miles per tank prior to the tank fix? As others have commented, in certain driving conditions, it's not abnormal to get 350 miles to the tank, even for the Hybrid RAV4. Most comments from people with the tank fix seem to indicate that, after the fix, they have more usable fuel before the re-fuel light comes ON (meaning more miles per tank than prior to the tank fix). Apparently, the fuel sending unit (fuel gage) was not reading properly (due to tank design), leading to too much reserve fuel remaining in the tank at the trigger of the re-fuel warning light.Just got the tank fix.
Strange. After fix I've had four fillips. All over 500 miles to go.Just got the tank fix.
Your reading Total MPG average.Empty light came on at 349.
Just a full tank. Was able to pump on 10.5 gallons.
Clicked at 10 gallons squeezed half a gallon more.
Before fuel tank fix I would pump in only 8 gallons .
Only averaging 350 miles per full tank of gas.
Distance till empty shoes about 440
On a full tank after fix.
Only getting 350 until the gas light turns on.
I will post again after the next fill up.
Try Changing the display to Tank MPG average.
My winter average is 36-38 and the summer is 38-42
your DTE will then be about 520-540 as the MPG increases over time.
But, agreed... 350 Miles per tank is Terrible, something is wrong
So am I reading it wrong ?
With a full tank with only 3 miles driven, DTE reads 445.
By the time the fuel warning light turns on I’m at only 350 miles.
I thought that, after the fuel tank fix, the fuel reserve at low fuel warning light ia supposed to go down to 2.5 gallons, matching the owners manual?You say your low fuel light comes on at trip odometer reading of 350 and tank takes approx.10 gallons. Your actual tank range is currently more like 470 miles + or - given your mpg is approx. 35 and tank capacity is 14.5 gallons minus 1 gallon slosh room. The low fuel light is just a reminder to gas up soon as you still have approx. 4 gallons left in fuel tank.
It sounds like you expect to drive 445 miles until the low fuel light comes on, which isn't quite right. The warning light should come on with about 30 miles left (plus a heavy amount of reserve fuel even when "empty"). This doesn't make a huge difference, but the fair comparison should be 380 vs 445.So am I reading it wrong ?
I have this same issue too.Empty light came on at 349.
