2022 Hybrid LTD Bezel for SS3 fog lights
397 Views 12 Replies 6 Participants Last post by  dummyvariable
2
Good day to y'all,
First-time posting here. Have a 2022 Rav4 Hybrid Limited and learned to see that the LED fog light is housed in a bezel that is not conducive to the SS3 replacement in the image below. The question is - where can a guy get that bezel for housing the upgraded SS3? I tried searching the forum already and can't find any direct links to this so far... any input is greatly appreciated.
this looks similar to OEM
this is what I am after!
22
1 - 13 of 13 Posts
Are you sure it won't fit the housing you showed? My SE didn't come with fog lights, but I used some generic kit off Amazon for the bezel/housing and wiring, then added the Diode Dynamics SS3 right in, and it looked like the bezel in the first picture.
I'm not an expert with Rav4s, but that second picture looks to be a different model year, like a 4th generation.
Reactions: 1
Good day to y'all,
Maybe I'm misunderstanding your issue, but here is what I think may be the problem:
The Diode dynamics SS3 fog lights do not have mounting brackets since they are made for many makes and models of cars. You have to buy them as a set with mounting brackets and wiring adapter for specific cars. Here is what the kit looks like for Toyotas:
With those mounting brackets and wiring adapter shown, the SS3 will fit anywhere the Toyota OEM fog lights fit, such as your top photo. Amazon sells the kits with the brackets and wiring adapters: https://www.amazon.com/2016-2020-Toyota-Tacoma-Diode-Dynamics/dp/B082VJ424Y
Reactions: 1
The ss3 came with the mounting brackets, the lights themselves are bigger than the existing ones. I'll contact the dealership and gem oem bezel parts.
Yea i just grabbed photos from google for this - its the Bezel itself, realizing that the LTD model uses a different light for the fog light systems.
Do you have a link to this generic kit?
If you have a 2022 Hybrid model, then the housing should be the same and I can't find one on OEM parts sites currently. Thanks in advance!
Good day to y'all,
22
Just an FYI, your before picture is a 5th Gen RAV4.
Your second picture is from a 2016-2018 4th Gen RAV4.
2
It sounds like you've got the newer style fog lamps, which have a little square-ish bezel around them and are smaller in diameter than the older style. These newer style look like so:
If so, you will want the older-style fog lamp trim, which is what's in your top image above. Assuming you have the correct brackets with your SS3s, they will fit in the older-style bezels just fine, though a small amount of the lens around the perimeter is covered up:
When I installed my SS3s, I got the bezels off eBay and was able to find them on there pretty cheap.
Reactions: 1
Diode Dynamics really needs to update their fitment page. I dealt with this issue and found out not only the connectors aren't compatible but the housing is too small, or properly match my 2023 rav4 limited (gas).
Per description page
Thanks for this input as well - I did just grab two images from the internet to get the point across! lol
This is my goal - do you have the links for this on Ebay/Amazon?
I found this link - suitable?
Either one of those ought to work. The first one comes with wiring, a relay, and a switch which you'll need anyway for the SS3s, though who knows what kind of quality it is or how much you might need to adapt it to work with the SS3s (like whether it's got OEM fog lamp connectors on it that the SS3 adapters can connect to, or something different).
1 - 13 of 13 Posts
