Good question. This is the first trip having it on there, so I'll let you guys know. The car will also be loaded down with gear, so not sure how accurate it will be as the cargo box won't be the only variable changing.looks good! What has been your regular MPGs since installing the rooftop cargo box?
Impressive! I eventually plan on adding a smaller thule cargo box and hopefully net results like this. Thanks!Good question. This is the first trip having it on there, so I'll let you guys know. The car will also be loaded down with gear, so not sure how accurate it will be as the cargo box won't be the only variable changing.
This is what I've avg'd the first 600 miles - with just the rack on.
387 miles later (with the cargo box on the whole time) and my MPG's improved.looks good! What has been your regular MPGs since installing the rooftop cargo box?
First tank was over 550 miles, can't remember exactly. Second tank I filled up at little under half way....ODO was at 880.How many miles did you get on your first few tanks?
