2023 RAV4 hybrid LE OEM trailer hitch?
351 Views 4 Replies 4 Participants Last post by  FKHeath
Howdy forum, has anyone installed an OEM trailer hitch on a 2023 hybrid LE? Part number PK960-42K10
The Toyota website says it's not compatible with 2023 model year, but I can't imagine it's that much different from 2022. There are some dealership websites that say it is compatible though. Is there an OEM hitch compatible with the 2023 hybrid LE?
Most online OEM parts stores still don't have '23 applications available, delay is normal for new models every year.
Just wanted to update here in case anyone finds this in the future. I installed the OEM hitch receiver part number PK960-42K10 on my 2023 Rav4 Hybrid LE and it was pretty quick and easy. It took me less than two hours start to finish. I did not install the wiring harness since I'm using it only for a bike rack. I may decide to install the harness in the future.
FYI if you disconnect the negative battery terminal on a car with Toyota Safety Sense (TSS) it will give some warnings on the dash about the pre collision system failing. I just had to drive maybe one mile and restart the car and the message went away.
I'd be happy to answer questions if anyone needs info.
I put a Curt trailer hitch from e-trailer on our 2021 Rav4 Hybrid LE. No problems. I had my local mechanic do the work, as I don't have a lift. At this point we don't have trailer wiring set up. Just using the trailer hitch for a Thule bike rack.
I think the aftermarket hitch is a lot cheaper than the OEM one. Check out etrailer, prices , save some money. I'm sure the dealers charge a lot to install the OEM too.
There is a section in the owners manual "Items to initialize" if the 12 volt battery is disconnected. That is all you need do.
The biggest one is the back hatch since it is probably open when you disconnect the battery on a hybrid/Prime. My back hatch would not close when I did the OEM wiring harness install until I did the initialization.
