255/55-19 tires anyone?
1.2K views 9 replies 4 participants last post by  Sierra Sam
Hi ,
anyone running 255/55-19 ?
no lift ?
with Lift ?
any problems , Rubbing ?
Thanks Eik E
I don't see why not. Look at what you have now. They are obviously worn, but still. You need 15 mm radially and 7 mm or so laterally in terms of clearance. If you compare new for new, you need 7 mm laterally and 11 mm radially, i.e sides and radius.
Just curious, why the larger size? Visual impact?
#9 ·
Let’s use something more factual then. The 235/55R19 can run snowchains on all four corners. There are also people running off-road tyres in 235/70R17.
If the snowchains clear on the inside and outside, the diameter itself is a non-issue. I ran 10mm chains in Norway last year.
