1 - 3 of 7 Posts
native_rav4
Discussion starter · #1 ·
what is everyone doing to get some more clearance? I haven't been able to find any substantial lift kits, but can you combine a spacer lift with the eibach spring lifts?
plenty of 2 inch lifts but I need about 4 inches really.
Discussion starter · #5 ·
Question, what do you need 4" for?
Don't forget that larger tires also raise ride height. On my 98 I installed a 2" lift and larger tires with a total lift of 3". I could get tires a little bigger and put spacers (As first gens 3" suspension is maximum before it possibly pulls the axles out) to get higher. Though I'd have to cut my wheel wells a little as I am already close to rubbing.
the problem with adding bigger tires is the rubbing. not really wanting to cut into anything to allow more room width wise but ill raise it to get some more clearance for bigger tires.
1 - 3 of 7 Posts
