1 - 2 of 2 Posts
Hi,
I am trying to put some winter tires on 2012 Sienna 17" alloy rims. they have the same wheels specs as 2012 Rav4 that I own. The wheels fit perfect on the rear but on the front, the calipers are scratching the inside of the rims. I am thinking about using a 3mm spacer to give it some room. I am wondering if I could use the stock studs or do I need or replace them with longer ones. Could someone help me here?
thanks in advance.
It does not fit perfect if it is rubbing the brakes. The offset is different. Just sell those and get ones that fit. You are not saving money and then having to buy spacers ?
1 - 2 of 2 Posts
