How do you dim the 7 inch touch screen at night time? In the manual it says go to settings then go to display. But I don't see the 3rd option to turn on/off the day mode. I have the 2016 Limited Hybrid.
You can only set day mode at night or cover the light sensor on the dash so it thinks it's night time, the day mode option will show then, the instrument panel lighting dimmer must be in the variable position as well, not in the upper position.
Correct. My 2016 had the dimmer switch locked in the UP position so everything was super bright at night. Just scroll it down to take it out of the lock position and the screen (as well as the instrument panel) will dim when the headlights turn on.
