S
SnlpeR
·Guest
quick description.
gf's rav4 overheats
no hot air comes out when heater is on
when a/c is on...temp drops
when you rev it up to 2k+ rpm...temp drops
this is what was done and replaced in order
flushed radiator as best i could
replaced the following
-thermostat
-timing belt
-water pump
-radiator cap
-crank seal
-cam seal
-oil pump seal
50/50 water/coolant
bled cooling system
car still does the same thing
no oil in coolant
no coolant in oil
whats left? radiator....
can a 10 year old radiator go bad all of a sudden
a lot of money was dumped on the car trying to figure out the cause of the overheating
im out of ideas after the radiator
gf's rav4 overheats
-thermostat
-timing belt
-water pump
-radiator cap
-crank seal
-cam seal
-oil pump seal
50/50 water/coolant
bled cooling system
no oil in coolant
no coolant in oil
