1 - 2 of 2 Posts
Hi guys, I am about to do my timing belt along with water pump, pulleys, timing cover gasket,cam/crankshaft seals, and drive belts. I bought a Dayco kit and my mechanic that it is the cheapest junk out there so I guess I'll return it and get an Aisin kit. In the dayco kit, there are 2 different sized tensioner springs and I can only seem to find one size anywhere else. How many springs are even in there?
Side note:anything else that I should get done while I'm in there?Am i missing anything?
Automatic 4door 1997 4.0 3sfe
I'm surprised by what your mechanic says about Dayco, they are one of the most popular kits sold by Rockauto to us Rav4 owners, I fitted one to my car a year or two back and have had no problems at all.
The reason they supply two springs is the earlier model uses a different one to the later model. There's only one tensioner and one spring used on the car. Sorry, right now I can't remember which one you need but call a Toyota dealer if in doubt and ask them for the part number for your car to match it up.
You should also change the oil pump seal and gasket, I always advise you buy these parts from your Toyota dealer as I received substandard aftermarket parts when I bought mine individually from Rockauto.
That said, Dayco sell a kit to include these parts now as well as the water pump and timing belt parts. I'd still get mine from Toyota.
Good luck.
1 - 2 of 2 Posts
