Ground strap and/or battery cables. And make sure the battery is fully charged, and the cables' terminals are clean and tight. Be safe -- lead, high amps, and explosive gases.
Check both ends of the battery cables. Make sure they are on the battery without a bunch of corrosion on them and tight. Then make sure the other end is free of rust and properly secured to the engine/frame/ground.
