My 2009 RAV4 Limited had an A/C issue a while back that was corrected by a mechanic, but seems to have come back - when the mechanic looked at it, he mentioned that two of the valves (the ones where you recharge the refrigerant) were leaking - so those were replaced, then he also mentioned that the clutch or something on the compressor was not engaging, and that it seemed to have a lot of "torque" from the compressor trying to work.
Whatever it was he fixed it and I was good for about a month and now it's blowing warm air again.
Could it be the same problem again, or something different?
I am on the East Coast of Florida - Vero Beach.
· Your Humble Administrator
How long is a while back? Can’t you take it back to that shop and tell them their repair didn’t work? Your compressor doesn’t have a clutch, it’s a variable displacement compressor that’s always on. If you would like to know more about the system, check out this pdf:
It also could be the flow sensor. Easy to test with a magnet:
It was about a month ago, the mechanic that looked at it for me, didn't charge me anything for the repair. I took it back to him today and he said we need to replace the compressor. Thanks for sending me the PDF. He is telling me I'm looking at about $1,000 for parts & labor.
Did you test the flow sensor?
Not yet, I have zero mechanical knowledge and wouldn't know where to begin, I need to thoroughly go through the resources you sent me and figure out what to do. I'll watch the video and see if I can figure out what to do.
I believe I read somewhere that can you put a magnet on the flow sensor and if the AC works then the sensor is no good.
Someone else might remember it better than I can.
I found the post.
