I'm still debating on where I want to install something. One of these days I will be researching installing a grill further back inside bumper area. I have seen pictures of the front of the RAV4 completely off and it appears that a screen of some sort can be installed through the access area achieved by removing the upper shroud cover. The one that's removed to access the horns. With that panel removed, you have access to the big aluminum bumper rail that the horn wires attach to to keep them from moving around. There is a gap between the condenser/radiator and this aluminum bumper. From pictures, it appears that a stiff screen can be slid down between this area and secured to the aluminum bumper. This way you can use just about color of screen since it will not be see but will create a barrier in front of the condenser/radiator.
Ok, so two take aways from these images
- These have the whole front shroud removed but access to this area doesn't excessively reduce access to the intended area.
- This version of the RAV4 doesn't have the shutters in the lower section but I don't believe they would get in the way. Research will eventual determine if this is true.
Thoughts?
Any researchers up for the challenge?
I just don't like the look of the tie wraps on the outside of that grill and if this works, they wouldn't be there.
Also, in theory, an upward screen could potentially be added the same way; attached to the aluminum bumper and fitted behind the horns.
My dad installed fiberglass window screen material onto his 1970 Ford F250 when he bought it new to keep bugs out of the radiator fins. It doesn't have A/C so there was no need for that protection. To this day, that screen is still there and it rest right on the face of the radiator and hang down covering the whole front of the radiator. That's where I got the idea.
