The Problem: Canada built without front tow hooks.
All photos here are from weeks after the install and i did not take any video either. I thought some people here might like to see one solution. Much better than what i did would be to have the hooks on the front bumper area where they belong. I was not going to take down the front and cut around on it though.
Throwing into the mix was my wish to add a skid plate. So, I ended up combining the two. I had a call with Nathan from NWP and he said he would consider adding tow hook threads to the gen5 skid plates.... but they haven't made any at all.
Having the tow hooks down by the skid plate might not be helpful when you're stuck in deep muck and need to be pulled out forward, but for lots and lots of other scenarios i have hooks.
I bought a LP skid plate because i didn't want to wait any longer and added a climbing bolt hanger "inside" the skid plate.
This is the bolt:
It's a Bonier bolt that has two hangers. Typically climbing bolts/hangers only have the left one. Using one that has both sides makes it so both hangers/hooks pull straight instead of tweaking slightly.
This bolt hanger has a 10mm hole. The supplied LP bolts are 1/2" or 12mm, so i needed to drill the hangers out to fit the hardware. Then I shortened the LP spacer by the thickness of the Bonier hanger to keep the skid plate at the right height.
The next photo is a side view of the installed set up. From the bottom up, you can see the bolt with washer, the skid plate, the Bonier hanger (Spray painted black. Don't ask me why i did that 🤷‍♂️), and then the LP spacer. The rest is the frame and other car parts. It's the same on the other side.
Instead of hooks with threads, I can clip a carabiner in either or both.
Some of this is different and unconventional, but i have access to all the climbing gear, ie bolt hangers and carabiners.
Strength: The Bonier hanger is rated to 30KN, so you could hang 2 rav4s off of one hanger. The LP bolts are 1/2" and there are 4 of them. Not sure what the shear rating is but it's 4x tons.
Ps: I ended up cutting the orig plastic under parts to fit the empty spaces that the LP skid plate misses.
This is the bolt:
