So here's my little contribution to the forum.
i had a stock limited for a little over a couple months now and liked the car a lot compared to the camry i used to own.
I was contemplating what i could do to the car including sound, rims and a nice carplay deck.
i'm ordering rims in the spring time because it's almost winter here now.
i've always liked the "murdered out" (all black) look on cars so i thought i'd try to go in that direction.
Things you'll need:
1) hopped on prodip.ca website for canada and ordered 6 cans of matt black. it is $10 a can off the site plus shipping and taxes. which is way cheaper than going to lowes where they charge you $20 a can plus tax which ends up around $23 per can. I've seen this stuff in the USA for $5/can which is a joke.
2) also ordered the spray gun trigger tool, it's about 5$ and well worth it, saves your thumbs
3) green tape (got it from the dollarstore and it was cheap and good quality
4) newspaper, lots of it, so you don't have plastidip where you don't want it
5) alcohol
6) rags
7) sonax wheel cleaner (absolutely fantastic stuff. sprays on green changes to red when it eats away at the grease and brake dust and makes cleaning super easy)
8) power washer
9) car jacks and stands
10) scrub brushes
here's a quick summary before pictures. i will keep this as short as possible.
-cleaning is a very crucial process before dipping.
- take wheels off, spray wheel cleaner and let sit. color of cleaner changes to red. When red brush the rim down to loosen anything that's still stuck on there. power wash the cleaner off dry with a rag. I had access to an air hose hooked up to a very nice compressor so that's how i dried the rims off. For a final measure I took a rag and wiped down the rims with alcohol to help remove anything else still on the rims after the cleaning. Let the rims dry.
While waiting, clean of the rest of the emblems with alcohol or degreaser and make sure it’s dry after. Tape around the desired area and add newspaper the keep overspray.
Spray light coats of dip on both the inner rim dish and the outside spoke area. You don’t have to spray the inside spokes cause no one ever sees it, just the dish of the rim. I did about 5-7 cots of dip on every rim front and inner rim.
Plasti dip is very forgiving, a few times it didn’t come out of the can as smoothly and you’ll get dripping or a west spot that has a heavier coat. My advice is not to do anything but just let it sit. It’s quite interesting because it seems to self level itself in the drying process.
Apply coats to all emblems and grill and leave about 10 minutes in between coats.
When finished with all your coats, removed all the tape and newpapers and start peeling off excess. Plasti dip actually breaks sharply when it hits the emblems so it looks super clean. Use toothpics to fish out spots in the letter O, A and anything else that requires it. Toothpics should not scratch your paint surface.
It took about 6-7 hours with cleaning, preping and painting. which also included a 1 hour lunch break.
I’m very satisfied with the look. So here it is for you guys to check out:
Things you'll need:
5) alcohol
6) rags
8) power washer
10) scrub brushes
