1 - 10 of 10 Posts
My Rav lit up the ABS light on the way home tonight. The only code was Speed Sensor A, but I cleared that and the ABS light is still on.
I inspected the 4 ABS leads and can't see anything obvious.
How do I tell which one is bad?
On my 99 a speed sensor error would throw a code of 31 to 34, and the code would indicate the wheel. Different years use different codes, so giving the year and as much about the actual code as you can, will get you the most help.
Reactions: Scotty Gunn
With the ABS light on and no codes, my 99 manual says to check for shorts in the ABS circuit then check the ABS Control Relay.
Scotty,
Knowing what year and model yours is might help us help you.
Hey Scotty,
When you got your code, was it through the obd-2 port under the dash, or did you do some magic under the hood and read the code from the flashing ABS light?
Discussion Starter · #9 ·
Hey Scotty,
obd2 port, I just read the actual text and didn't notice if there was a code associated with it.
Sorry, I was trying to lead you the wrong way.
The only On-Board-Diagnostics code that I see is the, DTC P0500 Vehicle Speed Sensor Malfunction.
Not an ABS malfunction, but might be able to trigger an ABS fault.
Just to note, the ABS error codes are displayed by having the ABS light, blink the codes to you.
1 - 10 of 10 Posts
