Quick question for those with more knowledge in here.
The ABS system in the RAV4 will it brake/release individually just the wheel that is spinning or it will apply/release force to the whole braking system?
In other words, are there individuals automatic valves for each wheel or the system operate as a whole?
Thanks
Ed
if its a 4 channel, 4 sensor abs system then each wheel should be braked individually. i think all abs systems nowadays are 4 channel, 4 sensor systems.
^^ What he said.
The RAV4 does use the 4-channel, 4-sensor ABS system. 3-channel, 4-sensor ABS is still fairly common but its use will decline.
I know how sure that if you have traction control then each wheel will have its own sensor
