ABS Sensor Install (Answered)
I have an '09 Front wheel drive. I just changed out the driver side hub bearing assembly, and broke the ABS sensor in the process. I have already ordered the new sensor, but have no idea how to change it. It seems pretty easy from what I can see, but need a bit of help. I can see that I need to take out a bolt that holds the sensor to the hub assembly, and then take the clips that hold the wire in place off, but once the wire goes up past the top of the fender well, I have no clue. Any help is welcomed.
Discussion Starter · #2 ·
ABS Question Answered
So, to answer my own question, and for anyone else who decides to change out your ABS sensor yourself, I found that there is a thin plastic cover that covers the fender well. One clip and one small bolt, and I was able to access the wiring connector for the ABS sensor. Everything else was super simple. Just in case you decide to change your wheel hub bearing assembly, make sure you remove the ABS sensor from the assembly first. It will save you about $200.
Thanks for this... just changed my front hub and broke the ABS sensor as well. I'll be tackling the replacement when it shows up tomorrow!
