Hello, I am new to the forum. I have a 2011 RAV4 Limited 4wd V6. Recently, the AC blower has begun to go in and out. Somedays it is fine. However, on other days the fan will start high and gradually taper off to not working. I’m not sure where to proceed as this is auto cooling not manual so there is no blower motor resistor. Should I replace the blower motor? Or, is there another part I should be looking at first?
Thanks!!!
DatGuy
I've got the same system in our Limited with no problems but being in FL you probably run your blower a lot more than we do, maybe 100% of the time.
In any case you'd need to measure the voltage at the motor to hopefully find out it's the failure not the control system.
Or maybe just buy this one for $81 since it comes with both the blower and the Control Module.
https://www.rockauto.com/en/moreinfo.php?pk=3809391&cc=1447041&jsn=384&jsn=384
Thank you for your suggestion. I will swap out the part and see what happens.
Thank you,
DatGuy
I have a 2015 RAV4 LE and the AC blower intermittently works. It will go a month and then comes back on. The switch for the blower motor will not blow under any position.
