Hello!
Recently the AC in my
2007 RAV4 sport 4cyl stopped working suddenly. The pressure is perfect and stays perfect in the lines so no leaks. It's a clutch less compressor so I can't tell if the compressor is working. There's no bubbles or anything in the sight glass it's just clear. The Ac light comes on and off when I turn it on. I've tested the high side pressure sensor with multimeter per repair manual conditions and it passed. I have not checked the Condensor, evaporator or dryer. How can I check those? What else should I check? Or could be the problem?
Thank you in advance!
Simon
Since you report that the refrigerant pressure is fine and that there aren't any bubbles in the sight glass that rules out a leak or leaks as the problem. Has the A/C fuse been checked and tested for continuity?
All fuses related to the Ac have been pulled and checked out fine. Since is clutch less there is just a big empty hole in the fuse box where that relay/fuse would go.
If you have checked all those things and they are fine then you must have help from ac repair specialist. They will have the full checkup and fix the issue that you are having with the unit.
Since the post was from two summers ago we hope the OP got the issue resolved but as often happens we've never heard from him/her again.
