Back in the old days, ACC could hold you at the set speed by braking/regen and/or engine braking. This was in fact a hybrid only feature never promoted from LS600hL through to Prius gen 3. A true set and forget solution.
However there is very little literature about the changes to its operation where if you’ve set a target speed, and you happen to be going downhill sufficiently to speed up, the dashboard that shows the target speed changes to an inversed display (white background on black text) of the set target speed and a warning beep.
I’ve not driven any other TSS2.0 (don’t work for Toyota anymore) to know if this is the new norm but has anyone had this experience?
