Here in N. America all RAV4's come with cruise control as standard equipment. So I assume you installed the stalk control? Make sure the ETCS fuse and/or relay is installed. If it still doesn't work maybe it wasn't wired for cruise at the factory.I installed an cruise control on my 2015 rav4 but doesn't work, any suggestions?
thanks in advance
Thanks JuneBug for replied, here the basic version come without the cruse control, could you please tell me where are located the fuse and relay? thanks in advance.Here in N. America all RAV4's come with cruise control as standard equipment. So I assume you installed the stalk control? Make sure the ETCS fuse and/or relay is installed. If it still doesn't work maybe it wasn't wired for cruise at the factory.
I'm not familiar with the 2015, but my 2008 has a fuse box under the dash behind the hood release. Also, there are 2 fuse/relay boxes under the hood--one near the battery, and the other on the opposite side. Look for ETCS (Electronic Throttle Control System) which is what they call the cruise control.Thanks JuneBug for replied, here the basic version come without the cruse control, could you please tell me where are located the fuse and relay? thanks in advance.
these fuse boxes:I'm not familiar with the 2015, but my 2008 has a fuse box under the dash behind the hood release. Also, there are 2 fuse/relay boxes under the hood--one near the battery, and the other on the opposite side. Look for ETCS (Electronic Throttle Control System) which is what they call the cruise control.
