(MP3 Folder Play Solved) Adding a CD Changer to Entune NAV JBL
RAV4 Entune NAV JBL system does not come with a CD player.
Today I tried to connect an old Isuzu (Toyota) 6-CD Changer to a 12-pin harness available on NAV JBL unit.
For some reason 12-pin CD-Changer harness is missing ACC and BAT.
So far I got a CD icon. When I press on it, the CD changer clicks and the screen goes black. No sound.
Dunno about CD changers today. They are almost retro already.
Why not go back another generation?
OK
I have received a USB to CD-Changer Port Adapter/MP3 Player.
Tested with Old FJ Cruiser Head Unit. Works well.
Does NOT work on RAV4 Entune player.
First problem - RAV4 Entune 12-Pin AVC-LAN "CD Changer" Port wiring is different. Missing +12BAT and ACC pins.
I wired it properly and got the CD icon - nothing happens when I press the CD icon.
Problem solved! Partially.
Now I can play mp3 files from CD, since USB does not play folders.
I have found it on eBay for $600 and installed an original 6.1" Toyota NAV/JBL headunit, but with a CD player.
Plug in play install. All wires match and all functions the same as my original 7" NAV/JBL headunit came with 2016 Limited.
The screen size is less, but look more sharp since it has same pixel resolution.
I did not install XM Radio, since poor satellite reception in Alaska.
All apps and functions are the same including car setup.
Original Entune headunit NAV with JBL - 100584
Replaced to Entune headunit NAV with JBL - 100324
