Not to bring a post back from the dead but I'm dealing with replacing these cables right now and this write up is a big help. There are two adjustments, one is the amount of throw the shoes have until they contact the drum, done with the star wheel in the drum, and the other is the amount of slack in the cable done inside the console. Usually you will not have to adjust the slack in the cable at the console but if you do, you do that after you have adjusted the shoes. You should have no more than a few clicks in the handle before you start to engage the lever that moves the shoes inside the drum.
