G
Mine is right off the floor. If it is hydraulic, theres not much you can do.
A
Yes there is ...
Look up behind the pedal and you will see a threaded bar leading to the master cylinder - this can be used to move the biting point as I understand it.
Guess someone will be along soon if I am wrong :D
A
Ha - we are in the middle of a summer heat wave - seems odd posting to someone in middle of short days ...
Let us know how you get on.
Yes there is ...
Yes you can get a bit of adjustment there
The clutch arm on my d4d had 2 positions it could go on inside the bell housing...not sure which I put it on when replacing my clutch n flywheel. But now my bitting point is just off the floor..
Sent from my SM-G930F using Tapatalk
