1 - 2 of 2 Posts
For those who have installed aftermarket stereo amplifiers...
No doubt you had to run at least 1 power cable from inside the cab to the engine compartment. I'm gonna do the same thing but I'm concerned about EMI noise (probably high-pitched whine) coupling into the power cable from the alternator. Did any of you encounter this? If so, did you install a noise filter?
Run your power cable on one side of the Rav and your audio cables on the other. Same goes for RCA cables and a subwoofer install. Long as you keep audio and power separate you'll be just fine.
1 - 2 of 2 Posts
