Does anyone know if replacing the rear springs will affect the toe?
Just prior to replacing the saggy springs, I replaced the struts and shocks. The alignment printout showed that the front caster exceeded the maximum spec and the rear camber was at the maximum.
Haven't had the alignment redone, but I'm guessing the caster and camber are now within spec, just not sure if the rear toe will be affected.
