I have a 99 rav4 4door MT awd I been building into a rally build. I'm in need of a rally suspension and while they have a lot of off-road and street suspension for this model I can't seem to find anything able to hold up to rally. So are there other cars' suspension that will fit this car that I can look into?
1999 Toyota RAV4 with 3MZ-FE 6 cylinder engine, camo wrap, OME lift, heavily modded
Check out https://www.drive2.ru/l/7209125/, you'll need to hit translate page unless you read Cyrillic. On Google Chrome some of the translation is nonsense but it's better than nothing.
I'll check it out .. after posting this I was looking into vehicle part codes and everything and even started looking into ryans newer rav4 rally build and it seems the rear is gunna be a problem the way it's set up. As no one makes a rally setup in the style the rav4 has however Ryan in his 2015 model built towers in the rear to allow a fitment of the spring on shock type
