1 - 20 of 648 Posts
Not sure how much all of these are, but I'll bet they're a damn sight cheaper than what Toyota wants for theirs ($820!)... :? A quick look around the Internet floats the two currently available at around $150 to $220 shipped...
(Note that Draw-Tite, Hidden Hitch and Reese are all owned by the same parent company Cequent)
Curt 13509 (PDF installation instructions)
Da'lan 757509 (company bought by Curt in 2003)
Draw-Tite Max-Frame 75432
Hidden Hitch 70785
Installation Guide (Adobe PDF)
Putnam (none yet)
Reese Value Receiver 44540
"Formed Round Tube Crossmember is Minimally Exposed Beneath the Bumper."
Sure Pull (none yet)
U-Haul 78432 (model number curiously close to Draw-Tite's)
Valley Industries 81642 (PDF installation instructions)
UPDATED 5/1/06
FWIW... the OEM Toyota hitch INCLUDES wiring for lights. I guess it's a $600 wiring job :wink:
Not bashing, but the wiring kits run $30-$60... I'm sure Toyota charges more than the $130-$170 these aftermarket guys want for the hitch... :wink:
S
First off I have an 02, but hey the prices should not be that different for the new model, unless someone is trying to really rip people off. I bought a hitch for $120, the harness from my dealer for $30, and they wired it for me for $40, nice and neat. It is a Reese shadow mount, there is a photo in my album
Well, for one, the 2006's hitches are Class III/IV, rated at 3500 lbs and have a 2-inch receiver box.
The best that was ever made for the previous RAV4's were Class III, but the bulk of them were Class I or II and older RAV4's only have a 1500 lbs tow rating.
S
Is it not just the V6 model with the 3500 lb capacity, the 4 is still just 1500(I could be wrong) Either way, it should not cost any more to have the wires installed
Discussion Starter #7
You are correct about the V6 vs. 4-cylinder tow ratings. However, in this case, the hitches have the Class III/IV rating, not necessarily the RAV. But it's the same hitch hardware, nonetheless. $150 (including shipping) for a Class III/IV hitch is great, considering your shadow mount was $120.
To date, I haven't seen a Class I or II hitch made for the 2006 and the aftermarket manufacturers may take some time deciding whether to make them. Their take might be "Why design and make two different rated hitch receivers when you can get by with one?" All depends on how many they'd sell, I suppose.
If there's a need for a tongue (shadow mount) or 1-1/4" hitch receiver with the 2006 RAV4, I'm sure someone will manufacture one.
You really have to be ignorant to buy an accessorie like a trailer hitch or stereo system from a dealership .
90% of the time they are waaay over priced (& sometimes of lesser quality) then what you can get else where .
The hitch for my 2000 Rav was $79 Can.
$820 U.S. for a hitch :shock:
Bwaa haa haa
According to the internet-all 2006 v6 Rav4's come with a factory hitch??? My wife and I are ordering ours tommorow and this is something we need to know.
The exact quote: The well-equipped base grade includes features such as Electronically-controlled Active Torque Control 4-wheel drive; Vehicle Stability Control (VSC) with Traction Control; AM/FM/CD/MP3 audio system with mini-jack; dual stage driver and passenger airbags; power windows and door locks; keyless entry; illuminated entry; Optitron gauges; dual glove box; cruise control; air conditioning with rear seat heater ducts; 60/40 folding rear seat; tonneau cover and cargo net; tilt/telescopic steering wheel; silver accented interior trim; dual power remote heated side mirrors; roof rack; 17” styled steel wheels; towing hitch on the V6 and more
I believe that it is only in Canada that all of the V6's will come with tow hitches as well as the towing package which raises the V6 towing capacity from 2000# to 3500#. The towing package includes a transmission cooler, a larger radiator, an upgraded fan coupling, an upgraded to 150A alternator, and trailer prewiring. When you consider the severe climate that we have in some parts of Canada, (it was -30C here this morning), it is probably a good decision to include these on all of the V6's. I emailed Toyota Canada on Jan 19/06 to confirm that the above is true but I am still waiting for a reply.
Called Toyota Canada and they had no hitch info
Harold,
I sent them an email on the hitch and they couldn't provide info. I called them and again they couldn't help. I thought calling Toyota Canada would get me answers but Karrock is the first to be able to show me any details on the hitch. 2' Rcvr hitch is good news. Will order V6 Sport in next couple of days.
Just ordered an 06 Sport V6 tonight. The salesman showed me a picture of the hitch-it is standard equipment on the V6.
Discussion Starter #13
eTrailer posted some actual photos of the Hidden Hitch 70785. I'm guessing that all three of the Cequent (Draw-Tite, Hidden Hitch, Reese) hitches will look identical, but you never know...
I just finished installing a Reese tow hitch on my 2006 Rav4 V6.
It certainly is an ugly looking thing. Cequent seems to have made no effert to tuck it up underneath to hide it but I'm sure that it will work just fine. The distance from the ground to the centre of the receiver is 12". The toughest part of the install is getting the muffler hanger pins out of the rubbers on the passenger side but a screwdriver and a bit of grunting go a long way. Tools required are a ratchet with a 17mm socket and a 6" extension to remove the factory tie-down bracket and a torque wrench with a 19mm socket and a 6" extension to install the hitch. Torque spec is 65 ft-lbs.
It seems to be identical to the Hidden Hitch version pictured in the previous post and even has the hidden hitch and Draw-Tite part numbers on the instructions.
G
Yeah, I'm looking at a few here in Ottawa and I have not seen hitches on any of them. Maybe they think that easterners don't need hitches! :wink:
Which Model for Reese?
Harold,
A local store where I am sells Reese hitches. Which product number/model did you get for the RAV4 '06?
I was just about to erase my post.
Thanks anyway.
But since we are on the subject on hitches, I plan to purchase a hitch so I can add a tubular bumper/step hitch to avoid pesky screw heads from other cars when they bump into me when they park. My last car's car had a whole minefield of them and I want to avoid it this time around. Any recommendations on bumper hitchs. I have seen these small one that are like arounf 12" - 16" wide. Anyone seen something wider to cover more of the rear bumper?
Plus having the option of putting up a bike rack via hitch is nice.
C
Thanks for the pics! Looks like a hitch! :wink:
So, I can assume that the top of the receiver box is 13" off the ground? How much further up is the bottom of the door opening?
I'm wondering how high the ball can be and still be able to open the back door.
Thanks!
1 - 20 of 648 Posts
