1 - 9 of 9 Posts
Mine's only a 4 , but it looks just like yours. Sure does seem like there should be a hose there, though.
Regardless of whether or not Mr Toyota thinks a hose should be there, I would install one. You probably will never see any fluid coming out the vent, but I think it needs some protection to keep out dirt.
Put on a piece of generic neoprene vacuum hose of the correct diameter and route it securely towards the bottom of the engine compartment.
BTW - how are you supposed to check the coolant level? Hot or cold? If cold then your tank is low.....
John Davies
Spokane WA
Thanks, that is just a shadow, it actually is all the way to the top, may be needing that vent tube, and if some were to come out it will run down that little "valley" and then spill right on a bunch of stuff. I think I will try to find a hose for that.
Excuse a dumb question but have you removed the cap and verified that the tube you feel a hose should go on actually is open and not sealed off??
Would check mine but my wife has escaped with the RAV for a couple of days (Big national dog show in Vancouver, WA)
Have been wondering if this may be used in a country configuration outside the US and is plugged for US versions.
Discussion Starter #7
Have not checked like that but I do remember my Camry had a small hose for the overflow that was attached to the cap.
Maybe it's an extra cost accessory? :shock:
I know Toyota has come out and admitted they might of went to far in their recent cost cutting measures. Maybe the overflow hose was deemed a great way to save a buck. (BTW the article where toyota admits this is the C&D highland first drive)
My RAV has no hose and my Mazdaspeed Miata has a right angle hose about 2 inches long that allows any overfill to drip about in the same place it would without the hose. Other than the cars rolling over, how could the fluid leak out? The containers are above the radiator and fluid can expand just so much before it blows apart something. Wouldn't the radiator cap or a hose leak first or would it send the excess pressure to the overfill tank? I haven't seen a car yet with a blown overfill tank but maybe it happens.
1 - 9 of 9 Posts
