No, dude. You have to run a wire from the ground terminal on the amp to a spot of bare metal on the body. Like where a bolt goes into the frame (ie. where the seat bolts to the floor). Then it will be grounded. Also try to keep the wire as short as possible and use 8 ga. if its not a real powerful amp. amp < 500 W
