2006 RAV4 X has four 18" run-flat 55 ratio tires (with unique five-spoke alloys) and no spare on the rear door -- far as I can tell from published photos, no hood scoop.
Is that sensor by the muffler?
Also, why do our cars disable traction control and 4WD when there's an issue? I almost always have a code scanner with me, so it's not a big deal since I can clear the code, but I didn't have one one day in a snowstorm and it was tricky getting home. Is the...
I have a 2009 Toyota Rav4 and today the front brakes locked up for no reason. This the second time that this has happened. You can smell the brakes overheating. The dealership could not find any problem the first time. The vehicle is at the dealership now. Has anyone else had this problem and if...
Hello I need to drain my fuel tank. I have tried to siphon the tank but it was a no go. When I take the hose out there is fuel on the bottom of the hose. Dropping the tank I cant do that because of the weather.
Now you may ask why I need to do well my wife was in a rush and the gas tank light...
Backing out of my drive is a short steepish up hill, if i put the car in reverse and back up and out without stopping ,no problem, but if i park on uphill part and try to start off in reverse, it shudders as i move off. i avoid it by running down and starting again on flat. Any ideas of the...
Hi
tried to search, but I’m stuck.
Both these lamps has come on, we have a 07 Rav. I have changed the brake switch, checked all the fuses, no luck. The brake lights are not working.
I checked the connector to the switch, and it only has 12v on 1 pin, when the ignition is on. I think this is...
