61 - 72 of 72 Posts
Tire rotation is free at any place you bought tires before even if you didn't get them for this car yet. Tire rotation is recommended at 7500. I usually do it at 10k.
Car wash is free too as they give coupon for a free car wash after any visit.
So pretty much $40 for a car wash and to check your wiper blades. It's a steal.
And $600 worth of damage to your paint
Sent from my SM-A102U using Tapatalk
I just had the 5K sevice. Totally free, even the cookies and coffee were free.
The service guys said you get 2 oil changes , for free, anytime you want during the first 25,000 miles. Spend it anyway you wish. I asked what would they suggest, and he said do it at 10,000.
So they did a tire rotation, and washed it , and some other checks.
All done in a half hour.
I like Toyota, and thats why I bought a Rav4
Edit: ignore me, i was completely wrong about oil changes.
first oil change at 10K?
I am changing my own oil this weekend at 1K
I did the same and I installed a Stahlbus valve to make future changes easier. Make sure you have a good filter wrench, mine was put on by a gorilla; my claw type filter wrench crushed the filter by 1/3 before it started to break loose.
I had to Google "Stahlbus" and I can't believe I've never heard of an oil drain plug valve! What size of Stahlbus fits our rav4?
I have a Stahbus valve, but I am sticking with removing the drain plug everytime. I want to make sure the old oil completely drains.
M12x1.25x12mm
It comes with a copper crush washer and just make sure you torque it to a maximum of 18 ft lbs as stated on the box.
Don’t be concerned with not being able to drain the oil completely because of the threads. One-time, I removed the Fumoto valve on my Subaru as an experiment to see if there was any truth to the concern and only a few drops came out, not even a steady stream or anything. There is already a significant amount of oil retained in the top end of an engine and there is no way of getting it all out during a basic oil change. I’m not concerned about a few drops.
I also have a Fumoto valve that I am not planning to use. Fumoto valves are famous for sticking out too much. For cars without plastic shields or covers, a rock or road debris could knock off the valve leading to the oil draining inadvertently. This is not a problem for the RAV4 2019/2020, but I still do not have 100% confidence a $50 aftermarket part will not fail and drain the oil inadvertently.
I had the 5K service done today. It was uneventful. I didn’t bother complaining again about the refueling issue and I had no other issues to report.
At 10k miles my XSE already needs new struts and has the fuel fill issue, this will be my first and last Toyota. So disappointed 😔
61 - 72 of 72 Posts
