I bought this kit and installed it on my 2016 RAV4 LE a week or so ago. The only part of the harness kit that I used was the dashboard switch. I used the factory harness and bought a relay at Auto Zone. I only used the switch contacts. The LEDs in the switch work with the kit harness, but not so well if you use the factory wiring. I wired one side of the switch contact to ground, and the other side to the white wire on pin 36 as described in other posts on this forum. I'm happy with the results.
Purchase Morimoto LED Fog lights from The Retrofit Source if you are going to be replacing fog lights. Light output is amazing, they look great and LED bulbs last forever.
