41 - 60 of 82 Posts
Discussion Starter #41
My 2015 XLE does not have auto lock with speed increasing and does not unlock when remove the key.
The only thing it has is Lock with shift to D and unlock when shift to P. which is pretty annoying because sometime you shift to P does not mean you get out immediately.
Can you disable that feature using the touch screen? If so, then the module will probably work. The one I have only unlocks the doors when you turn the key to OFF.
Discussion Starter #43
Got mine in the mail from the original link OP provided. Works great.
Just got mine! T01-2 and it does what I wanted. Locks doors at 12 mph and unlocks them when you turn the key to off. Also, if a door is opened for any reason, say at a stop light or ATM, it relocks it when you get back up to 12 mph. Sweet. E_V
Discussion Starter #47
Another thing I noticed with this module. If you stop to pick up someone, and unlock the doors using the power lock button, it does NOT re-lock when you reach 12 MPH. Since you unlocked manually, you must re-lock manually.
Mine does.
I find that if you unlock my drivers door, manually by the toggle above the latch handle, It does not re-lock. If I actually open the door, then it re-locks.
Discussion Starter #50
That's exactly how mine works. It would seem that Veliksam's is different.
I'm going to double check mine to make sure I'm not imagining things but I'm pretty sure it does function the way I described. LOL
Has anyone checked to see if this module will display the 'mode' using the door light and the lock switch? Just thinking out loud. E_V
Discussion Starter #54
Mine would relock after manually unlock for passenger to get in.
Yes, when using the manual latch under the door handle. But not after using the power door lock button on the front doors, right?
What about module for lock when door open?
Has anyone seen a module which will allow locking the doors when one is open? It drives me crazy not to be able to:
1) Open door to unload groceries, children, cargo
2) Lock door
3) Put keys in pocket
4) Grab all of the items
5) Shut door with my butt/teeth, whatever I can
6) Walk away
You would not believe how many times this comes up, pretty much every time exiting the vehicle, and it doesn't appear to be configurable.
Discussion Starter #59
2) Lock door
6) Walk away
Nope, the way I do it:
2) Hold black door switch down
3) Push lock button on remote
4) Put keys in pocket
5) Grab all of the items
6) Shut door with butt, walk away
41 - 60 of 82 Posts
