Hi folks,
If anyone could lend a hand in diagnosing the auto headlight feature of a 2010 Limited Rav4, it would be appreciated. All the lights work fine when in manual mode. my first thought is the sensor. Unfortunately there's two on top of the dash and don't know which to charge or how. Thanks in advance.
The "moved" reply was because he moved this thread to the correct subforum, you posted it in the wrong forum.
IIRC one of those "bumps" doesn't do anything, the solar sensor should dim the instrument panel lights (if it's working) if you cover it when the headlight switch is in auto, would be a way of testing it in daylight. There's also a 1-5 sensitivity setting that may be set wrong. The manual should be more help than my memory tho!
