1 - 19 of 19 Posts
Was driving my 2012 RAV4 2.5L FWD today on the highway and the red Auto LSD light started to flash on and the check engine light came on too. Doesn't seem to be anything wrong with how it drives, but the lights don't go off. Turned the traction control on and off several times, but didn't do anything.
Thoughts on what is wrong and any way to fix without taking to dealer?
While not necessary to go to a dealer, you will have to take it somewhere to have the codes read and then it can be determined what needs to be done.
Try the paperclip trick from the dash light thread in the mechanical forum? Your lights don't totally match the most common descriptions but you might be able to figure something out
Paper clip trick is old school LOL....go to an auto parts store and ask them to read your codes....most of them do it for free and will give you a printout of the reading....
Paper clip trick may be old school but it can read ABS, traction control, and auto LSD codes from the anti-skid computer. Your code reader at the auto parts store can only read engine codes. LOL
Any idea on what this might be? The same lights just came on my wife's 2011 Rav. I hear a buzzing noise from under the hood when the key is in "run" before cranking the engine.
Turns out the DTC from Auto Zone was P0171- System too lean. Took it to Dealership as the car is under extended warranty, and they diagnosed the problem as a purge valve stuck open. My guess is that since the purge valve was stuck open the engine was sucking in air thus causing the lean code.
Thats happened to me a month ago, i use my Techstream to check find that there are two misfires in cylinders 2 and 4 , i did a clan the error in the techstream software and they gone out.
I have a same going on right now. Got my it figured with my OBD code reader, showing code 0138 which is O2 sensor. Apparently ECU figures that there is malfunction in the engine monitoring and cutting off LSD, which causing the flashing warning light. So, I am going to check o2 sensor first.
Hiwd
How'd this go? Thx
I know this is an old post but wanted to add this information for possible future issues that someone may have.....My daughters 2012 had this issue, blinking Auto LSD with CEL. This occurred very soon after an oil change so I was suspicious that the crew at the quick change maybe fooled around with something. I found a hose pulled out of the air flow pipe near the mass flow sensor. I know they pulled the cover to check on the air filter and this is probably when the hose pulled out so I will give them the benefit of the doubt that they did not do this on purpose. Anyway I pulled the negative cable on the battery to reset the lights and the problem went away and has not returned.
Thank you! This just happened to my daughter’s car after an oil change. Sure enough! It was the air intake hose. Thanks!
I had this come up a while back. I talked with a service advisor and she said it was a solenoid to advance/retard the camshaft. The usual cause was debris in the engine oil. Changing the oil may have dislodged a bit of debris.
I was getting on the verge of replacing he solenoid units, but after 3 or 4 episodes, it went away and hasn't been a problem since.
Mine does the same damned thing but I've noticed it always seems to be on very wet, rainy days (or for a day or so afterwards), it's stupid as hell, I basically treat it as a "hey it's moist!" notification 🙄
That's not something that I would leave as-is. Maybe is just an ABS sensor that is cracked. Or can be something worse.
Example: My colleague had issues happening on wet days for about a year (not just code, but vibrations too). Took the car to 3 different shops that wanted to replace the AC compressor, alternator, accessory belt idler (that one he accepted)...
Only to see one day that the serpentine belt was miss-aligned on the new tensioner. Took the car to the shop only to find out that the rubber on the harmonic balancer was basically broken apart and the balancer pulley was "walking out" from crankshaft. That would have damaged lots of things if really flew out while driving.
The same rubber broke off in my Sonata and was making squeaking noises when road was wet (water spray). I only find it when I was doing timing belt, when I saw that the timing marks where completely off (that separated part rotated).
Thank you, too! Wow, this is fashionable. Your post saved me just now!
Auto LSD light and Check Engine light is on...Great advice, I had my 2011 RAV4 inspected this past weekend and oil changed. As usual they tried to upsell me with an airfilter. Needless to say, I popped the hood and there's a hose disconnected. I connected it, but the lights are still on. I disconnected the Negative cable on the battery and started the vehicle back up. No lights :), Thanks....
I had the same issue of having check engine light on with blinking Auto LSD light on my 2012 Rav4. As stated in the previous threads here, the hose that connects to the engine was loose after checking the air filter. I reconnected the hose, disconnect the negative pole of the battery and reconnect, and then the those warning lights are gone! Thank you so much for sharing this info!!
1 - 19 of 19 Posts
