1 - 8 of 8 Posts
Hello, did anyone try to mount but installed an aliexpress system for automatic folding mirror?
150684
Discussion Starter #2
I have a problem with the installation. does not work as it should, i.e. folding mirrors from the remote control after opening or closing the car. And it should open after starting the ignition. Maybe someone had a similar problem or managed it.
I don't see why not, folding mirrors wirings should be identical. Mine doesn't have birds view.
hmm, apparently they are not compatible, might be the extra cables for the blind spot monitoring light and the cameras mounted on the mirrors.
I messaged the seller and also found this description on their page (a similar product from the same seller)
I really wanted them.
Sent from my SM-G970F using Tapatalk
Too bad you're out of luck. Some other vendor on eB** sell similar device, will check if I can find it.
Sent from my SM-G935F using Tapatalk
1 - 8 of 8 Posts
