2012 Rav4. Both the console and rear auxiliary power sockets died between one trip and the next - no apparent reason. The fuse under the dash (may that fuse block be cursed for all eternity) is all right. I changed it out anyway, no change. I pulled the relay in the dash, checked it, swapped it, and finally jumpered it with no change. Volt meter says there is no power at the relay - wish I'd checked that first but it seems like this entire job has to be done the hard way. Checking around can't find anything else that lost power yet, just the accessory sockets.
I CANNOT find where the power comes from to supply power to the relay. Any help? We NEED those plugs to power my father's oxygen.
By the way. I made my own tool to reach up inside that cursed upside down fuse block if anyone's interested. It's the only way I've been able to pull or replace fuses. Now I'm finding all sorts of unrelated uses for it.
