AUXITO LED Light Bulbs for 2019 2020 2021 Toyota Rav4
1442 Views 0 Replies 1 Participant Last post by  Valli AUXITO
With the top LED bulb upgrade for the Toyota RAV4 from AUXITO, you now have the option to improve your 2019-2021 Toyota RAV4's stock lighting.
This LED bulb set is available for the 2019-2021 Toyota RAV4 LE, LE Hybrid, XLE, XLE Hybrid, XLE Premium, Adventure, XSE Hybrid, Limited, and Limited Hybrid. All LED bulbs are plug-and-play and require no modifications.
LED Bulbs replacement model & technical specifications
Fog Light Bulbs H11
  • 2000lm/bulb, 4000lm/set
  • 6000K Xenon White/ 3000K Golden Yellow
  • 1:1 same light filament position
Front Turn Signal Lights 7443
  • DC9-18V, 1600LM/PC, Amber yellow/white
  • Dual-color function: The switchback turn signal flashes 'amber-off-amber-off' instead of 'amber-white-amber-white', much easier to be seen. Fit for dual filament socket. They will light up with white color as the low-filament running light/parking light, and switch to bright amber any time when you hit the turn signal.
Rear Turn Signal Lights 7440
  • Power: 24W
  • Voltage: DC12-24V
  • Light Color: 1500K Amber
Back-Up Light Bulb 921/912
  • Color: 6000K White
  • Lumen: 2600lm/Pair
  • Working Voltage: DC12V
  • Working Power: 5.5W
  • Current: 0.45A
Map LightT10/194
  • 3020SMD led chips, 2w per bulb, 6000K bright white, 360°illumination, and 300% brighter than a halogen bulb.
Amber Front Side Marker Light T10/194
  • 3020SMD led chips, 2w per bulb, 3000K amber yellow, 360°illumination, and 300% brighter than a halogen bulb.
Reactions: 1
1 - 1 of 1 Posts
1 - 1 of 1 Posts
