I trust you mean L/100km... Did this jump coincide with the colder weather and using the heater/defroster?
That's because you're an American and don't appreciate that most of the rest of the Planet operates, unit wise, in metric. Don't worry, you're not alone!3.8 sounds like a kilometres/kWh number to me and who displays fuel/distance instead of distance/fuel? I haven't seen the Canadian display but I would expect it to display Km/kWh and Km/litre.
Right - and wrong. Yes I am an ignorant American regarding Fuel efficiency conventions in Canada (and elsewhere).But I am not ignorant of the metric system, how broadly used it is, or of the advantages it provides. I just don't get why the fuel amount would be numerated over an arbitrary distance of 100 km. In the US they invert the values for gas guzzling power boats to gallons/hour but that is just because hours is how they track engine use and hours/gallon would be fractional. I understand why the units are different but not why they are inverted. It probably just comes from differences in philosophy. Now that I think about it I am going to eat my words. My original thought was that I want to know how far I can go on a unit of fuel but unless you can't afford to fill your tank (not a laughing matter these days) most people want to go from one specific place to another (and know about how far that is) so fuel / 100 units would probably mean more to them. With the R4P having an EV range of 68 kilometers it would probably be more meaningful to know kWh/10kilometers but that would break comparisons with true EVs.That's because you're an American and don't appreciate that most of the rest of the Planet operates, unit wise, in metric. Don't worry, you're not alone!
Fuel use is in l/100km in Canada, Europe, and most of the rest of the World. Electricity use is kWh/100 kms. Consistent and comparable (unlike the basterdized miles/kWh, seriously this is crazy!)
Uh, it’s “miles per gallon” and “miles per kilowatt hour” in the US, which doesn’t qualify as “bastardized”, as both measure energy use in miles traveled, just as the Canadian version does. The more obvious problem in the Prime PHEV is when owners (and Toyota) blend the EV and HV miles traveled together and call it “mpg”, thus leading to absurd efficiency claims. While I can’t test my assumption, I would guess that the Canadian Prime also blends HV and EV miles in the electronic readouts, and calls it “L/100km”, which is just as dumb.That's because you're an American and don't appreciate that most of the rest of the Planet operates, unit wise, in metric. Don't worry, you're not alone!
Hello, thank you for your time and input . It is much appreciated.I’m showing I overall. This is why I don’t understand why it suddenly changed so drastically
It's called the metric system, not "let's mix units from every regional system together with metric units to come up with random units !Uh, it’s “miles per gallon” and “miles per kilowatt hour” in the US, which doesn’t qualify as “bastardized”, as both measure energy use in miles traveled, just as the Canadian version does. The more obvious problem in the Prime PHEV is when owners (and Toyota) blend the EV and HV miles traveled together and call it “mpg”, thus leading to absurd efficiency claims. While I can’t test my assumption, I would guess that the Canadian Prime also blends HV and EV miles in the electronic readouts, and calls it “L/100km”, which is just as dumb.
The 4.6 l/100 km indicated are the calculation of the liters consumed net of the electricity consumed. The more you drive in EV, the lower that value drops, the more you drive with the internal combustion engine, the higher that value rises.Hello, thank you for your time and input . It is much appreciated.
I just wanted to show you a picture of the dashboard in case you spot anything I missed.
the average went down to 4.6 since last week, but it was at 3.8 for a very long time until dec22 and suddenly jumped.
