1 - 2 of 2 Posts
My A/C died, its a 2009 V6 Sport, got the B1422 Compressor lock read out, I googled a lot, couldn't find the Compressor lock sensor, but eventually, found it, I removed the passenger side head light to get to it, and measured 250 ohm on the sensor, manual says 125 ohm at 20 degrees centigrade, mine was 30..
Anyways, while I had the headlight out I decided to spray some brake cleaner into the AC clutch, and....it fixed the problem...... I was worried that I needed to remove the compressor, maybe even need a new one.....
Hope this helps others with the same problem...
Interesting solution for what could have been an expensive problem to sort out. Hopefully your experience will help others with the same problem, as you have indicated.
1 - 2 of 2 Posts
