Hi, I have a 2009 Toyota RAV4 that I purchased not too long ago (about two years) from a dealership. It recently was having issues starting. I checked to see what my OBD2 scanner could bring up, and it gave me a single code for B2799 - "Engine Immobilizer Malfunction". This seems likely since the fuel pump will not prime when turning the key, and it will not start. I have two keys, but both of their remote starts have stopped working. The battery is brand new (not sure if that matters). I searched on these forums and it seems that a few other people have had similar problems, but I have not seen a solution. Is this something I can fix myself, or should I search for professional repair? Thanks.
Sounds like you have an aftermarket remote start system that now failed.
Do you have Techstream? That might provide more information.
Hey, thanks for your response. I unfortunately don't, and although I'd like to know why this is happening, I haven't had much time to wait. I towed the car to a private mechanic. If this doesn't work out I might have to take it to a Toyota dealership. My best guess is that the key's battery has died and the car won't turn itself on due to the encoding. I will try to add further updates if I know anything else.
