back hatch tie down
46 views 3 replies 4 participants last post by  CoffeeBear
I have a 2019 XLE with power lift hatch. Recently I move something large and it hung out a bit. I tied the hatch down. This caused a constant beep warning when the car was moving indicating the hatch was unlocked. Is there a way to stop the beeping? Does this action damage the lift motor or hinge? thanks
#2 ·
To disable the open rear hatch alarm on a Toyota RAV4, use the vehicle's settings menu on the steering wheel to adjust the power back door (PBD) volume to the lowest setting or turn off the system entirely for hands-free operation. Alternatively, for a temporary solution or if you need the door open, you can use the remote to disarm the alarm before closing the hatch or insert an object like a carabiner into the latch to simulate the closed position. .......SO SAYS GOOGLE.
