Hi everyone,
I am installing a Pioneer AVH-X391BHS in my 2012 Rav4 Base . on the connector to the Headunit(HU), there is a Violet/White wire that needs to be connected to reverse light to power/signal the HU when put in reverse. Rather than running wire from HU to the back of the car, I am thinking about connecting to the reverse cable in the fuse box on the driver side. in the 28-pin connector slot "2" which could have helped is empty.
Can someone please tell me how to locate the reverse wire in the fuse panel?
thank you.
Pry open this panel to the left of the steering column:
And use the red wire for your reverse trigger:
