Through the mirror, the led and buzzer:
The pictures are also on my album...
I normally installs and do all the mechanics for my cars, and since the first time I installed a backup sensor on my old cars... with a new car it should be a must.... I am so used to it, that if I drive a car without it... I feel like in danger... is like when you use air condition in your car... after you got a car with it, you can not live without it.....
Well, first is to take off the cover from the rear door.
start from down to up.. they are pins that release with some presure on them.
2.- open when is the lifter tool, and try to locate the bulb from the rear back light. (the one white that turn on when in reverse), and then attache the cables from the sensor units to it... and then the cable trhough the tube to the rear door place.
3, then select the right place to paste the ultrasonic sensors, and then direct the cables to inside of the rear door...
4.- paste the controller inside, tag the cables...
5.- paste the led on middle up of the door..
and then put the cover again... and you got it...
Very nice. I definitely need one of these after shattering the bumper backing into the concrete surrounding a light pole on my other car.
hope this help other people
