I have an 2014 RAV limited. If my headlight switch is set to AUTO when I shift into reverse the backup camera comes on bright immediately.
If I have the headlight switch set to ON, when I shift into reverse the display comes on very dim for about 15 seconds, then brightens to full brightness.
I would like to know if others with this vehicle have the same issue.
See page 400 in the manual, enable(or disable) Day Mode, instrument panel lighting control needs to be in the variable position if it's the same as the '15-on, not sure on the '14.
Well, I went to the dealer about 4 times for this issue when I bought it. They supposedly talked to Toyota techs. Then I wrote to Toyota and even put a complaint on NTSB site. Never an answer.
It appears that your post answered it.
I went to DISPLAY and set DAYTIME MODE and also had to set BRIGHTNESS. but it appears to work now.
THANK YOU!!!
