Hi mate. I got issues with my 2007 2.4 petrol rav4. Alternator is charging 14.2v Battery current sensor is new battery is new. I checked fuses all OK. But battery light keep coming up on dash intermittent. Fault started about 500km after i connected auxiliary battery. Auxiliary battery is disconnected but fault still present
Since you mentioned replacement of the current sensor, it sounds like you may have already read this thread, but if you haven't, then give it a read. The thread gives several suggestions to help diagnose the problem.
I need to ask why you replaced the current sensor in the first place?. Is the clamp on the battery post tight? Is the small connector pushed on tightly?
Welcome! First I recommend choosing a user name that isn't an email which just invites spammers.
Do you know the voltage is holding when the light comes on? I use a voltmeter/usb charger plugged into a 12V outlet for continuous monitoring.
