1 - 17 of 17 Posts
Thanks for the video:
Can you try the following for owners that need our car in Mph please?
1. Set your car to MPH / MPG using the steering wheel controls and the in-dashboard screen
2. Make sure your odometer is in MPG
3. Turn the car off
4. Wait until the android unit goes to sleep
5. Turn the car on
6. Check what units the odometer is in now.
The Seicane unit switches the car to KPH anytime is turned on. I'd like to know if the Dasaita unit has the same problem.
Thanks!
Hi. I will test it, but does Seicane HU show music info in dash? With Dasaita it do not show it and this cable will not be connected what send this information. For me its okay.
It does not show information in the dash about the music, but somehow the Seicaine unit switches the whole car to KPH via the Can Decoder.
Thanks for doing the test, it will help a lot of MPH users that had that issue with Seicane!
Thank you for your review!!! Unbelievable that Toyo cant produce something like that .
Does the unit support factory microphone or external one needed?
Also what about backup camera and proximity sensors?
Will Android auto work on the unit without need in connection to phone or can you still co next phone for AA?
Also I saw you didn't screw it to the car, how sturdy is it, any movement?
Thank you again.
Sent from my Pixel 2 XL using Tapatalk
Discussion Starter #7
This head unit have internal mic on left corner and external mic is included, factory mic wont work.
Backup camera and parking sensors work same as original. You can use android auto by connecting it with wire but its android unit,
you can have all your apps installed there. And there is other car mode apps too.
Thank you, I saw you didn't screw it to the car, how sturdy is it, any movement?
Thank you again.
Cant find a way to change it to MPH / MPG .
Hi, using the steering wheel controls look in the dashboard screen for the Gear Icon. Then scroll to "Settings" and leave the "Ok" button long pressed until it enters the settings menu. You will find at the bottom a units option, and there you can switch to MPH.
Thanks
Wondering if anyone checked to see if Dasaita head unit changes speedometer from MPH to KPH like the Seicane head unit. Thanks!
1 - 17 of 17 Posts
