$80 each on tire rack right now in 225/65/17. I considered getting these as I am not in need of need winter tires. But do not want to go run flat due to the cons. But if you have a SAP and need run flats WOW. This is a smoking deal!!
BridgestoneÂ*Blizzak LM-80 RFT
I was thinking of getting those instead of Mich Latitude X-ice X12's. What would be the downside with the Blizzak LM-80s. If it's about the road noise, I get that as I took the all-season run flats off my Rav4 and put on some decent Firestone tires (picked these as they were cheap and had a great deal on them).
Just the general RFT negatives. Ride comfort being the top. Next would be weight. Most tires in this size weigh 29lbs. These are 35 which results in a slight loss of acceleration and mpgs. The last would be wear. Generally RFT wear faster. tougher carcass is said to accelerate wear 1 by using a softer thread rubber to compensate and 2 by not allowing the tire to conform to road irregularities and thus more stress to the thread rubber. I did notice that the thread depths of these are 11/32 vs the 13/32" of some others. But this is not a big issue due as the tire I am looking at only has 10/32s" to start with.
Regardless if you have a SAP without the spare you should be running RFT and thus these would be a great option.
I ended up getting the non-RFT (Mich Latitude X-ice X12's). Paid $133 per tire. I needed a quieter tire than the RFT's. If Blizzaks were for my BMW X1 I would have jumped on it, but since the Rav4 can be a bit louder, I have gone with the non-RFT's, the tire inflator spray and AAA. Might consider looking for a donut tire for longer trips. I thought I read that the Honda CRV donut tire would fit on the Rav4.
